IP камера Dahua DH-SD50120T-HN скоростная купольная поворотная EcoSavy 2 1.3Мп с 12x оптическим увеличением, PoE+ (уценка)
Dahua
EndOfSale
Артикул:DH-SD50120T-HN (уценка)
Код товара: 31292
Dahua
IP камера Dahua DH-SD50120T-HN скоростная купольная поворотная EcoSavy 2 1.3Мп с 12x оптическим увеличением, PoE+.Камера бывшего употребления, работает только от PoE. Следы монтажа, царапины, комплектация полная
Снят с продажи
Model DH-SD50120T-HN
Camera
Image Sensor 1/3” CMOS
Effective Pixels 1280(H) x 960(V), 1.3Megapixels
Scanning System Progressive
Electronic Shutter Speed 1/3 ~ 1/30,000s
Min. Illumination Color: 0.05Lux@F1.4; B/W: 0.005Lux@F1.4
S/N Ratio More than 55dB
Camera Features
Day/Night Auto(ICR) / Color / B/W
Backlight Compensation BLC / HLC / DWDR (Digital WDR)
White Balance Auto, ATW, Indoor, Outdoor, Manual
Gain Control Auto / Manual
Noise Reduction Ultra DNR (2D/3D)
Privacy Masking Up to 24 areas
Digital Zoom 16x
Lens
Focal Length 4.7mm~94mm(20x Optical zoom)
Max Aperture F1.4~ F2.6
Focus Control Auto / Manual
Angle of View H: 54.1° ~ 3.2°
Close Focus Distance 100mm~ 1000mm
PTZ
Pan/Tilt Range Pan: 0° ~ 360° endless; Tilt: 0° ~ 90°, auto flip 180°
Manual Control Speed Pan: 0.1° ~350° /s; Tilt: 0.1° ~250° /s
Preset Speed Pan: 500° /s; Tilt: 500° /s
Preset 300
PTZ Mode 5 Pattern, 8 Tour, Auto Pan, Auto Scan
Speed Setup Human-oriented focal length/ speed adaptation
Power up Action Auto restore to previous PTZ and lens status after power failure
Idle Motion Activate Preset/ Pan/ Scan/ Tour/ Pattern if there is no command in the specified period
Video
Compression H.264 / MJPEG
Resolution 1.3M(1280×960)/ 720P(1280×720) / D1(704×576/ 704×480) /CIF
(352×288/352×240)
Frame Rate Main Stream 1080P/ D1 (1 ~ 25/30fps), 720P(1~50/60fps)
Sub Stream 1 D1/CIF(1 ~ 25/30fps)
  Sub Stream 2 720P/ D1/ CIF (1 ~ 25/30fps)
Bit Rate H.264: 448K ~ 8192Kbps
Audio
Compression G.711a / G.711Mu(32kbps)/ PCM(128kbps)
Interface 1/1 channel In/Out
Intelligent Function
IVS Tripwire, Intrusion, Abandoned Object Detection, Missing Object Detection
Face Detection Support
Network
Ethernet RJ-45 (10/100Base-T)
Protocol IPv4/ IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS,
Compatibility ONVIF PSIA CGI
Max. User Access 20 users
Smart Phone iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot Micro SD, Max 64GB
Alarm 2/1 channel In/Out
General
Power Supply AC24V/1.5A (±10%), POE Plus(802.3at)
Power Consumption 13W, 23W (Heater on) 13W
Working Environment -40ºC ~ 60ºC / Less than 90% RH -20ºC ~ 60ºC / Less than 90% RH
Ingress Protection IP67, IK10 IK10
Dimensions Φ186.0(mm) x 253(mm) Φ198(mm) x 177(mm)
Weight 2.5Kg 2.2Kg
