RAID-контроллер LSI 9341-8i, 12Gb/s SAS/SATA 8-port int.
Форм-фактор контроллера | Плата Расширения |
Стандарт разъема подключения | PCI Express 3.0 x8 |
Размер внутреннего отсека для накопителей | Low Profile |
Тип канала данных | SAS/SATA |
Скорость передачи данных | 12 Гбит/с |
Количество каналов ввода/вывода | 8 |
Количество поддерживаемых устройств | 64 |
Поддерживаемые уровни RAID | Level 0 Level 1 Level 10 Level 5 Level 50 |
Характеристики контроллера | • Online Capacity Expansion (OCE) • Online RAID Level Migration (RLM) • Auto resume after loss of system power during array rebuild or RLM • Single controller multipathing (Load balancing) • Drive hot plug support • Drive roaming • Selectable logical drive as boot drive • Virtual Disk (VD) Consistency Check • Fast initialization for quick array setup • Staggered disk spin up • Hot Spare support (up to 8) –Global, dedicated (copy back), enclosure affinity and emergency SATA support • Automatic rebuild support • SafeStore Encryption Services for SED HDDs • Shielded state drive diagnostic technology • Patrol Read media scan and repair • Online HDD firmware update • Error recovery support • SAS TCQ support • SATA NCQ support • Support for native 4K HDDs • Non disk device support • >2TB logical drive support • Soft bad block management • DDF-compliant Configuration on Disk • Foreign Configuration Import • S.M.A.R.T. support • SES (inband) & SGPIO (sideband) management |
Mini SAS HD | 2 (SFF-8643) |
